* Login   * Register * FAQ    * Search
  View unanswered posts | View active topics It is currently 18 Feb 2019, 05:58
Post new topic Reply to topic  [ 3 posts ]
 Post subject: Login Issues
PostPosted: 28 Mar 2013, 08:43
Homeshard: Drachenfels
Played Since: The Second Age
Greetings Citizens
Since the maintenance last night, some people are still having issues with connecting this morning.
This is due to the login server changed IP address in the process.
EDIT: First of all, if your pc was on during the whole thing, it is suggested to restart it, if that don't work, read on.
If your PC are not able to connect there are 3 potential workarounds. They are:
Step 1.
Power of your router/modem, wait about 30 seconds, then power it back on, if problem persist continue to step 2.
Step 2.
In "Run" (XP), or Search field in start menu (Win7), type "CMD" and run it (it is command prompt). in it type:
Code:
ipconfig /flushdns
If problem persist continue to step 3.
Step 3.
This is a temporary solution and you will need to remove this entry if you experience problems in future (when the ip change again).
Locate c:\windows\system32\drivers\etc\hosts and open it in notepad
On a blank line put the following
Code:
107.23.176.74 login.ultimaonline.com
Without a # infront.
Save file as you found it, some versions of windows might want to play tricks on you and add .txt, is important it is saved without any extension.
Safe Travels
-The Knuckleheads
 Post subject: Re: Login Issues
PostPosted: 28 Mar 2013, 20:38
Thanks alot - you are a great help!
I don´t believe in Tangle - it doesn´t exist!
PostPosted: 28 Mar 2013, 22:51
Thanks a lot. :)
Funny thing is the hosts entry worked flawlessly this morning...now after the patch I'm locked out again xD Cuuurse you patch
  Home ›› Forum ›› Knucklehead News
Users browsing this forum: No registered users and 1 guest
cron
